AD Integration with CallManager 4.1.3
With synchronization between CallManager 4.1.3 and AD, can CallManager refer to a different field than "Phone" to populate the "Telephone Number" field?
1 REPLY
Re: AD Integration with CallManager 4.1.3
no you cannot, the plugin does not let you choose which fields you want to use
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
102
