09-15-2008 04:18 AM - edited 03-15-2019 01:15 PM
I have set up AD sync with cm 6.1, Just wanted to check that if I am not using LDAP authentication does the password I have set in AD for each user sync across initially? the password field is populated but it only works if I reset the password from CM, when I do a sync does it set the password to a default?
Solved! Go to Solution.
09-15-2008 04:52 AM
No, the password does not get replicated to CUCM from AD. Not sure what the default is. Use BAT to reset all pwds to a known default.
LDAP Auth works pretty well, why aren't you using it?
09-15-2008 04:52 AM
09-15-2008 05:02 AM
I will just wanted to test all the features. I take the default password is not one that is known.
07-21-2009 05:57 AM
The default password is ciscocisco and the PIN 12345.
