Community Member
AD script for Telephone Number edit
hey guys...anyone have an AD script for editing the telephone number field in AD? All in prep for LDAP import to CUCM.
Thanks.
1 ACCEPTED SOLUTION
Super Bronze
Re: AD script for Telephone Number edit
Update from where....?
There's lots of resource out there for this sort of thing - I'd look for a WSH (Windows Script Host) script that you can either use as-is or modify. VB based ones tend to be the easiest to understand.
Here's an example you could try ; http://www.wisesoft.co.uk/scripts/vbscript_update_user_attributes_from_csv.aspx
One word of warning - with any of these things it's best to attempt with a source that will affect only a handful of records, and then ensure that the changes worked as expected before doing your full user set.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
1 REPLY
Super Bronze
Aaron
233
