add a new subscriber into cucm 7 cluster
alberto.orden
hi to all,
I want to add a new subscriber into a cluster, i have a cucm 7 Publisher, i add the server on it and then i install the subscriber but when i put the data of the CUCM 7 fails, if i ping the subscriber from the Publisher is ok.
Need some help,
Best regards,
Alberto
alberto.orden
Any guide to add a new subscriber so I have a CCMPublisher and CCMSubscriber.
Version 7
Best regards
Install Software from a DVD on a Subsequent Node
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_0_1/install/cmins701.html#wp350770
java
if this helps, please rate
java
