Add Area Code Call Manager
I was wondering if it is possible to have Call Manager add the area code to a call? We have a branch office that has it own local gateway. When someone places a call from the branch they only have to dial 7 digits for the local call. If possible I would like to reroute calls out of our HQ if their local pri is down. During the time that the local pri is down is it possible to have call manager add the local area code for phones in that branch when their calls are being routed out the HQ pri.
1 ACCEPTED SOLUTION
Re: Add Area Code Call Manager
all calls with that route list
java
if this helps, please rate
java
www.cisco.com/go/pdi
yes, configure the prefix under the route list for that route pattern
java
java
Will that add the are code on all calls though?
java
java
Excellent thanks
1286
