Add Cell Phone to Cisco ISR 2911
I would like to know if it is possible for me to get an interface for my ISR router that would allow me to connect a cell phone. Reason been I would like to make some configuration to route my VoIP users through a cell phone whenever they are making calls to a Cellular phone.
I have a Cisco 2911 and also running CUCM 10.5 server. Please help.
1 ACCEPTED SOLUTION
Hi.Unfortunately no gsm modue
Hi.
Unfortunately no gsm modue for voice is available, data only.
There are a lot of gsm gateway which can talk SIP or H323 with CUCM/CUCME and they are external boxes.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.I don't think it's
Hi.
I don't think it's possible but there are many GSM gateway event with low price to achieve this.
Carlo
would you know if this exist
would you know if this exist as a network module that can be added on to a Cisco router or is it a separate appliance.
Hi.
Carlo
If it is least cost call
If it is least cost call routing you are after, you will need to deploy a GSM gateway,  which is configured as a SIP trunk from a CUCM point of view.  it contains a bunch of SIM cards and has an external antenna, these guys make it:  http://www.topex.ro/
Please remember to rate useful posts, by clicking on the stars below.
49
