Add different new DID blocks in call manager
I have did blocks 6828 7000 to 6828 7699 running in call manager and use two isdn-30 lines in 3745 routers to ptt for incoming/outgoing call. I will add new did blocks 6829-3100 to 6829-3199 in call manager and voice router. any suggestion or reference to customzie the voice router to support two set of did blocks in call manager. I am useing h323 to ptt.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Add different new DID blocks in call manager
There is nothing special you need to do, simply add new dialpeer(s) matching this range and point to CCM. The dial-peer destination-pattern will be based on however many significant digits the telco is sending to you, so for example assuming that telco is sending you 8 digits, then create the following dial-peer:
dial-peer voice 100 voip
destination-pattern 682931..
session-target ipv4:
codec <>
no vad
HTH, please rate all helpful posts!
Chris
1 REPLY
codec <>
no vad
Chris
503
