Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Add'l PVDM hardware detected, not available
I've installed a second PVDM and the hw shows up in sh diag, but I can't use the voice-card 1 or 2 to utilized for transcoding or conferencing. I've attached sh ver and sh diag. The unit is a 2821 with CME 4.3/7.0. Any ideas on this whether it's a licensing issue or bug?
Thanks in advance!
1 REPLY
Hall of Fame Super Silver
Re: Add'l PVDM hardware detected, not available
All PVDM modules installed on the motherboard are part of the voice-card 0, voice-card 1, etc are for the Network Modules (NM) cards. So, this works as it should, you can simply go back to the transcoder and conference bridge configuration and see if you can increase the max-sessions configuration.
Chris
132
