Community Member
Add Mail ID and Departament to Corporate Directory
I need add the Mail ID and Department in the Ip Phone Corporate Directory Menu. I have a CUCM 5.1
1 ACCEPTED SOLUTION
Re: Add Mail ID and Departament to Corporate Directory
no, if you have worked with CUCM it's clear why it's that way
1 we only provide that basic directory script, so if you want to add anything else, it needs customization which only DEV team can provide within Cisco
2 you cannot access the tomcat folders in CUCM due to the security restrictions, you cannot place anything because root access is needed (and we do not provide it for those purposes)
it's the same as idle url:
Cisco CallManager 5.x and later
For Cisco CallManager 5.x and later, put the XML file, which the previous procedure created, in a web server and point the URL Idle field in System > Enterprise Parameters to the web server.
Note: Access to the CCMCIP folder on the Cisco CallManager 5.x servers is restricted and can only be done if you have root access.
java
if this helps, please rate
java
www.cisco.com/go/pdi
you need to develop your own directory script if you need that, also you need another web server to place this script
java
java
Community Member
Thanks Jaime
Do you have the paper where say that?
Regards.
Cristian
java
java
199
