Add new range of phone numbers to call manager 9.x
Sorry if this is a beginner question. Our company had a CUCM/CUPS/IM/UCCX/QM 9 solution installed for our IP phone system and call centre. When it was installed we had a block of 100 numbers (1111 1100 - 1111 1199) configured which we have now out grown.
We have purchased another block of from our telco (2222 2200 - 2222 2299) and need to integrate these into our system.
I was hoping someone could point me in the direction of some documentation on how to integrate these into our system, or is this a task that we should seek to contract out?
Thanks in advance.
Everyone's tags (1)
1 ACCEPTED SOLUTION
You need to determine how
You need to determine how many digits you're going to use and how your dial plan will look like, before anything else, then you config the GW (assuming H323/SIP) with the new DPs and the GW/trunk config in CUCM to handle the new DNs. If MGCP, just the MGCP GW config, and all dial plan config will be in CUCM.
There's not one doc at cisco.com to tell you how to do this step by step, they only come by pieces, and assume you have knowledge of GW and CUCM.
There are some GW-CUCM config guides for all protocols, but you need to know how your dial plan will look like to configure accordingly.
If you have little experience with CUCM, you might want to get a consultant to avoid problems with your current config.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks Jamie, that definitely
Thanks Jamie, that definitely sounds outside my skill level at the moment, so a consultant will probably be the best option.
Re: Thanks Jamie, that definitely
I have added the below new new DID range -+1-814-462-XXXX [5700 – 5899] for one of the dummy site : NAUSCHICAGO
1- Created the incoming translation rule on gateway.
2- Created the Outgoing translation rule on gateway.
3- Created the GDPR pattern -85585 [78]XX on CUCM.
4- Checked the translation pattern for 8558XXXX range.
5- Checked the dial-peer settings on the gateway for range 8558XXXX."
417
