Add Port to h323 Dial-peer
Trying to add a new bri port to an existing h323 gw, which has 2 bri's already configured. When creating dial peer, I cannot select new bri port. do I need to reset the h323 in order to see the new port in dialpeer config? thanks
Hall of Fame Super Silver
Re: Add Port to h323 Dial-peer
First of all is the card even detected? Does it show under "sh diag", second of all is there a voice-port in the configuration?
Chris
Shows up under show diag, and sho run.
voice port config is missing, cannot add 0/0/0
interface BRI0/0/0
no ip address
encapsulation hdlc
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
Bronze
You may have been probably forgotten "isdn layer-1 emulate" and "isdn protocol-emulate network" commands.
Hope the following link helps...
http://www.cisco.com/en/US/docs/ios/12_1/12_1xi/feature/guide/dt_brint.html
And I surprised to see HDLC encapsulation on the interface.
Regards..
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
that looks like a global command. 2 BRI ports are already working. Is this an interface command? Also, tried removing the hdlc encap, keeps coming back.
110
