Add prefix 9 for incoming calling number of missed call only.
qilin zhang
Dear,
I am wondering how to add the prefix 9 to incoming calling number of missed calls only, not the calling alerting number on the phone screen. For example, the local user 472 2001 calls our DID 482 3001 along with the calling number 472 2001 on the dialed phone screen, if I missed this call, in the directory missed call I can see 94722001.
I know I can add the prefix in the field incoming called party subscriber prefix on the gateway page, but when I do this, all of the calling number information show 9.
Kirin
Marwan ALshawi
If you are tuning CUCM version 7 and later you can achieve this as per bellow
Prefix the 9 as desired to the calling number as you did
Create a calling number transformation to match any calling number stater with 9 "9.!"
then discard pre dot in the calling number transformation
Give this calling number transformation a new partition let's call it P1
Create a new CSS call it C1 for example that contains P1 partition
Assign this CSS to the phones in the calling number transformation CSS on the phne settings
This will take effect for the calling number during dining stage
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03trpat.html
Hope this help
If helpful rate
19 Replies 19
Marwan ALshawi
Hope this help
If helpful rate
Did this solve your problem, I am interested in the same thing?
If I understand you correctly, you would like to only change the missed calls/placed calls on your phones without changing the digits?
If you have an PRI, you can use this translation rule to change calling ID only on inbound calls:
Translation pattern to modify Caller ID to add a 9
voice translation-rule 1
Rule #  /match/ /set/
(^.= Match anything begining with any number)(*= one or more digits) tranlasate to (9& = Take whatever is in the match phase and plug it in here)
rule 1 /^.*/ /9&/ type subscriber subscriber (subscriber = ton(Ton=Type of number) value local area)
rule 2 /^.*/ /91&/ type national national (national = ton value long distance area)
rule 3 /^.*/ /9011&/ type international international (international = ton value international area)
Config t
voice translation-profile INBOUND_PSTN
translate calling 1
voice-port X/X/X
translation-profile incoming INBOUND_PSTN
Let me know if this helps.
John
John the original poster wants to present the calling number of the incoming call without the 9 but in the missed call to be with 9
So the above config will do the prefix only
To hide this 9 during the riming stage you have to do the suggestion I provided above using calling number transformation
Hope this help
Ok great, I am always learning new ways to do things with CUCM.
Cheers
U'r welcome :)
Hi Marwanshawi,
I did what you told me, but when I use the calling number transformation CSS to phone, the missed call information will also display the calling number which 9 is removed.
Kirin
Without the leading 9
What do your missed calls show the calling numbers starting with ?
Alex
Regards, Alex. Please rate useful posts.
Are you sure the 9 is being prefixed at first place to the calling number ?
Are using h323 iOS translation rule to do the pre fix or gateway level settings for incoming calling number ?
9 is added under H323 gateway using Incoming Calling Party Settings in the subscriber number prefix, and removed using the calling party number transformation on Phones. So after completing the above configuration, the calling number on the phone screen will display without 9 and missed calling number with 9, is that right? But I find 9 is dropped not only calling number but also missed calling number.
Anything else I missed? I notice that Phone and H323 gateway are under same device pool which has same calling party transforamtion CSS. Because Use Device Pool Calling Party Transformation CSS is selected under gateway configuration page, will the gateway drop the 9 using the Calling Party Transformation pattern first?
Kirin
If you are using the CSS on the device pool level and the gateway is using same device pool them this is the issue
You can uncheck the check box use device pool CSS for the incoming calling number in the gateway settings pge
Because this will lead to remove the 9 ad the gateway level
But I your case since the 9 being prefixed in the h323gateaay level then nothing has to be change in the gateway setting in CUCM
Hope this help
I am wondering if this feature is phone-type-depend? Currently I am using 7960.
Kirin
It should be ok
Just make sure you set it up correctly
