Add Prefix to local extension when making VOIP calls
aadhu1
Hi Guys,
  i would need help on the transilation rules for eg. the ip phone extension of mine which is 86128 should be seen to other end as 12386128 and that too i need only for one site office , i had tried transilation-rule which says rule 1 /^86.../ /123/ and added to dial-peer as transilation-profile outgoing "name" . could you please help on this one , cant figure out how to change the local extension .
2 Accepted Solutions
Hi.
Another way to translate could be
voice translation-rule 100
rule 1 /^5...$/ /123\0/
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Adarsh.
voice translation-profile AUH-Test
you have
translate called 3
should be
translate calling 3
Carlo
7 Replies 7
Dragan Ilic
Level 4
Level 4
http://draganchilly.blogspot.com/2009/11/call-manager-and-call-manager-express.html
especially this:
CME advanced examples:
/^\(5..\)/ /1234\1/
- match numbers in 500-599 range and transform it in 1234500-1234599
HTH,
Dragan
HTH,
Dragan
Hi.
Carlo
aadhu1
Hi Dragan/Carlo,
I had tried both of ur transilation rules but its the same , my extension no: is not getting changed with the added prefix 123 to the other side call ... is there any other rule u guys can think of ....
Sent from Cisco Technical Support Android App
Hi ,
Can you paste the section of config which contains translation rule , profile and dial-peer.
Manish
Hi Manish,
This is the config , you can see the translation rule 3 is the one for this purpose and is named as AUH-Test , and the profile have been added to dial-peer to where the prefix of the local extension should be changed and shown to the remote end with the added prefix .
rule 1 /^30/ /9/
rule 2 /973/ /9/
rule 3 /111/ /91/
rule 4 /444/ /90/
rule 5 /20/ /99/
rule 6 /^968/ /9/
voice translation-rule 2
rule 1 /44/ //
voice translation-rule 3
rule 1 /^86...$/ /123\1/
translate called 3
voice translation-profile remove-prefix
translate called 1
voice translation-profile uk-prefix
translate called 2
dial-peer voice 72000 voip
translation-profile outgoing AUH-Test
destination-pattern 72...
session target ipv4:10.28.2.2
codec g711ulaw
Adarsh
Hi Adarsh.
you have
translate called 3
should be
translate calling 3
Carlo
Many Thanks Carlo , that did worked , missed out the "calling" on that translate rule .
Thanks All for the help .
