Community Member
Add Prefix to local extension when making VOIP calls
Hi Guys,
  i would need help on the transilation rules for eg. the ip phone extension of mine which is 86128 should be seen to other end as 12386128 and that too i need only for one site office , i had tried transilation-rule which says rule 1 /^86.../ /123/ and added to dial-peer as transilation-profile outgoing "name" . could you please help on this one , cant figure out how to change the local extension .
2 ACCEPTED SOLUTIONS
Hi.
Another way to translate could be
voice translation-rule 100
rule 1 /^5...$/ /123\0/
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Re:Add Prefix to local extension when making VOIP calls
Hi Adarsh.
voice translation-profile AUH-Test
you have
translate called 3
should be
translate calling 3
Carlo
Silver
http://draganchilly.blogspot.com/2009/11/call-manager-and-call-manager-express.html
especially this:
CME advanced examples:
/^\(5..\)/ /1234\1/
- match numbers in 500-599 range and transform it in 1234500-1234599
HTH,
Dragan
HTH, Dragan
Hi.
Carlo
Community Member
Hi Dragan/Carlo,
I had tried both of ur transilation rules but its the same , my extension no: is not getting changed with the added prefix 123 to the other side call ... is there any other rule u guys can think of ....
Sent from Cisco Technical Support Android App
Hi ,
Can you paste the section of config which contains translation rule , profile and dial-peer.
Manish
Community Member
Hi Manish,
This is the config , you can see the translation rule 3 is the one for this purpose and is named as AUH-Test , and the profile have been added to dial-peer to where the prefix of the local extension should be changed and shown to the remote end with the added prefix .
rule 1 /^30/ /9/
rule 2 /973/ /9/
rule 3 /111/ /91/
rule 4 /444/ /90/
rule 5 /20/ /99/
rule 6 /^968/ /9/
voice translation-rule 2
rule 1 /44/ //
voice translation-rule 3
rule 1 /^86...$/ /123\1/
translate called 3
voice translation-profile remove-prefix
translate called 1
voice translation-profile uk-prefix
translate called 2
dial-peer voice 72000 voip
translation-profile outgoing AUH-Test
destination-pattern 72...
session target ipv4:10.28.2.2
codec g711ulaw
Adarsh
Hi Adarsh.
you have
translate called 3
should be
translate calling 3
Carlo
Community Member
Many Thanks Carlo , that did worked , missed out the "calling" on that translate rule .
Thanks All for the help .
252
