Add Prefixes with Translation Rule
Hi,can somebody help me with translation-rule.
I need add prefixes to individual called numbers.
My scheme:CCM4(77xxx dial plan)<->7204VXR<->Meridian(72xxx,73xxx dial plan)
Example:
Number from ccm 77001 calls to some numbers 72001 73001,call go thrue 7204VXR were to the called numbers add prefixe "6",like 672001 673001.
If I use something like this, it works,but for all who go thrue dial-peer 10.
voice translation-rule 1
rule 1 /^/ /6/
voice translation-profile profile1
translate calling 1
dial-peer voice 10 pots
translation-profile outgoing profile1
And I need to add prefixes only to individual numbers.
Super Bronze
Re: Add Prefixes with Translation Rule
You can be more specific on the numbers matched:
rule 1 /^\(7....$\)/ /6\1/
Would prefix a 6 to any 5-digit number starting with a 7.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
If you only want to translate calls to 72001 and 73001, you could use a configuration like:
rule 1 /^72001$/ /672001/
rule 2 /^73001$/ /673001/
translate called 1
Hope this helps. If so, please rate the post.
Brandon
voice translation-rule 2
rule 1 /^\(77555$\)/ /6\1/
voice translation-profile 2
translate called 2
dial-peer voice 77 voip
tone ringback alert-no-PI
destination-pattern 77...
progress_ind setup enable 1
voice-class codec 1
session target ipv4:10.10.0.50
no vad
dial-peer voice 72 pots
tanslation-profile incoming 2
translation-profile outgoing 2
preference 1
destination-pattern 72...
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 1/1:15
prefix 72
Here is my config,but it dont do what I need.
If I understand correct "translation-rule 2"
adds prefix 6 to number 77555 when someone called on 77555 (if 72001 call to 77555 it calls to 677555)
I try to explain what I need again.Here my Scheme.
CCM4(77...)<-->7204(dial-peer 72... ,73...)<-->Meridian(72... , 73...)
If I call "ONLY" from number 77555 to 72001,73002,73002... I need add prefixes to numbers where I calls from 77555(672001,673002,673002...)
1452
