Community Member
Add the 8831 Conference phone to CUCME 9.1
How to add the 8831 Conference phone to Cisco Unified Communications Manager Express 9.1.
I could not find the device type to add  in my CME.
Please, tell me the steps for installation 8831 using CLI.
Everyone's tags (1)
Because you need at least
Because you need at least CUCME 10 for that phone model, upgrade and try again.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
 Check this Call-Control
Check this
Call-Control Support
Cisco Unified Communications ManagerThe phone supports Cisco Unified Communications Manager (Cisco UCM) Releases 7.1(5), 8.5(1), 8.6(2), 9.0, and later.
Cisco Business Edition 3000The phone is supported on the Cisco Business Edition 3000 Releases 8.6(1) and later.
Cisco Business Edition 6000The phone is supported on the Cisco Business Edition 6000 Releases 8.6(5) and later.
Cisco Unified Communications Manager ExpressThe phone is supported on Cisco Unified Communications Manager Express (CME) Versions 15.3(2)T, PI21, 15.3(3)T, PI22, and later.
Purple
HiSergey, As correctly said
HiSergey,
As correctly said by Jaime[+5] , you need CME 10
You can refer the link for CME 10
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme10spc.html
What u are referring is IOS version of router?
regds,
aman
Community Member
We have 15.2 (4) M6. I think
We have 15.2 (4) M6. I think about upgrade to CME 10, but we do not have active SmartNET now.
Purple
Hi, I was checking the
I was checking the ordering guide for CME and Contract is mandatory for upgrades.
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps4625/cme_ordering_guide.pdf
Customers who want to upgrade the Cisco Unified Communications Manager Express version must upgrade the Cisco IOS Software version running on the Cisco IOS Software router. Customers who have a current Cisco SMARTnet contract for the router can download the new Cisco IOS Software from Cisco.com and upgrade the Cisco Unified CME with SRST version on the router.
regds,
aman
Community Member
Solution:1) upgrade iOS to154
Solution:
1) upgrade iOS to 154-2.T (it's included CUCME 10)
2) copy to flash last firmware for 8831
2)
voice register pool-type  8831
 num-lines 3
 reference-pooltype 7975
voice register global
 load 8831 sip8831.9-3-3-5.loads
tftp-server flash0:cmterm-8831-sip.9-3-3-5.cop.sgn
tftp-server flash0:sip8831.9-3-3-5.loads
Purple
Hi Sergey ,thanks for update
Hi Sergey ,
thanks for update.
So, finally you upgraded router IOS to 15.4-2T.
If u do not mind, can u share output of show version/show flash/show running/show license feature and show telephony-service all
regds,
aman
449
