I'm be able to add 3rd party SIP Phone (X-lite) to CCM 5.0.4. But I got thiss error message when I'm trying to make call to PSTN or GSM mobile. "service not available". Provided that the call is successful with the Cisco SCCP IP Communicator
IntroductionCUCM Routing RulesDial String implementation PolicyCUCM Routing LogicSIP URI Call Routing Analysis+++ Case Study: 1 ++++++ Case Study: 2 +++Conclusion
Introduction
Over the last few months, I have had the privilege of working on SI...
view more
Hi All,
Are you getting this error “Installer User Interface Mode Not Supported. The installer cannot run in this UI mode. To specify the interface mode, use the -i command-line option, followed by the UI mode identifier. The value UI mode identifiers...
view more
