Added music-on-hold audio doesn't play on Call Manager 8.6
I have added the a music-on-hold file with the right settings on Call Manager and did configure with multicast settings but doesn't have any luck with the music, it is quite. I have tried with different  bit rate like 48, 32, 16 khz and restarting the IP media service without any luck. When I select the default sample media on phone's line settings, it plays the sample music. Anybody has any idea how to resolve this issue?
Thanks.
have you used the following guide to configure moh:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fsmoh.html
also, are you using multicast music on hold, streamed from localised moh files on like an SRST configured router?
Please remember to rate useful posts, by clicking on the stars below.
Blue
Are you using ‘Common device configuration’. If yes please Remove MOH file from ‘Common device configuration’.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I am not using Common device configuration.
In have the same problem, maybe someone could fix this problem?
Best Regards.
Juan Carlos.
Re: Added music-on-hold audio doesn't play on Call Manager 8.6
I have the same problem started suddenly, it was playing all files but stopped one day.
Now its playing only cisco sample audio file.
Is it a bug or any specific solution available ?
Solved, music file has to be uploaded to all servers unlike configuration which is done from publisher console
2546
