adding 2811 as MGCP voice gateway to CUCM 8.x
I've copied running config from a 2811 on a CUCM and copied it to a new 2811.  I've changed the IP addresses and I can ping the CUCM from the new 2811, but it doesn't register.  I've added the new 2811 to the CUCM 8.x and configured 1 port for testing, but it will not register - I do get battery on the ports but no DT on the test port I configured.  It was added as an MGCP gateway in the CUCM and the CUCM publisher and subscriber were added to the 2811's config.
Thank you!
"I believe that the greatest work of God has not been in the miraculous, nor in the spectacular, incomprehensible Creation, but rather I believe it was accomplished on the Cross where He Himself purchased the redemption of His Bride... the salvation of m
4 ACCEPTED SOLUTIONS
VIP Purple
Re: adding 2811 as MGCP voice gateway to CUCM 8.x
Hi George,
Can u share the configuration snapshot from Call Manager [Device---Gateway]?
regds,
aman
Re:adding 2811 as MGCP voice gateway to CUCM 8.x
Like Jaime said your missing the bind command, try bouncing the mgcp stack by adding the command "no mgcp, mgcp".
Can u take the output of the following command
Show ccm-manager
Do check if u r putting in the right domain name.
-Kevin
Sent from Cisco Technical Support Android App
This is an example, adjust as necessary for your environment
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Mgcp bind control source interface gig 0/0
Mgcp bind media source interface gig 0/0
Inserted below is the majority of the show run ...
Building configuration...
Current configuration : 4000 bytes
version 12.4
no service pad
service password-encryption
hostname test2811
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
enable secret 5
no aaa new-model
clock timezone PST -8
clock summer-time DST recurring
ip source-route
ip cef
no ip domain lookup
ip domain name testdomain.com
no ipv6 cef
ntp source FastEthernet0/0
voice-card 0
interface FastEthernet0/0
description test LAN
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
description production LAN
ip address 139.241.97.9 255.255.255.192
duplex auto
speed auto
no ip http server
ip http authentication local
logging facility local1
ip default-gateway 139.241.97.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 139.241.97.1
control-plane
voice-port 0/1/0
echo-cancel coverage 64
description Extension 2051
voice-port 0/1/1
description Extension 2052
voice-port 0/1/2
description Extension 2053
voice-port 0/1/3
description Extension 2054
voice-port 0/2/0
description Extension 2055
voice-port 0/2/1
description Extension 2056
voice-port 0/2/2
description Extension 2057
voice-port 0/2/3
description Extension 2058
ccm-manager redundant-host 139.241.97.21
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 139.241.97.22 139.241.97.21
ccm-manager config
mgcp
mgcp call-agent 139.241.97.22 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 200 voip
destination-pattern 2095
dtmf-relay h245-alphanumeric
dial-peer voice 1 pots
service mgcpapp
port 0/1/0
...this continues through port 8 ...
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
Thank you!!!
Have you tried no mgcp/mgcp??
Have you tried binding the signaling to an interface??
Is the proper name being used in CUCM??
Are the right cards/interfaces chosen in CUCM??
java
java
VIP Purple
Hi George,
regds,
aman
thank you for the input Aman... the 2811's domain name was the issue
Hi Jaime, thank you for your reply...
Have you tried no mgcp/mgcp??  <--- just tried it and it did not help w/ registration
Have you tried binding the signaling to an interface?? <--- ?? please provide more information on how to accomplish this
Is the proper name being used in CUCM??  <--- yes, double checked
Are the right cards/interfaces chosen in CUCM??  <--- yes
thank you!!
java
java
Show ccm-manager
-Kevin
Thank you guys for your help!!!
... here is the show ccm-manager before registration ...
test2811#show ccm-manager
MGCP Domain Name: test2811.testdomain.com
Priority        Status                   Host
Primary         Registered               139.241.97.22
First Backup    Backup Ready             139.241.97.21
Second Backup   None
Current active Call Manager:    139.241.97.22
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            17:58:51 PST Feb 5 2014 (elapsed time: 00:00:10)
Last MGCP traffic time:         17:58:51 PST Feb 5 2014 (elapsed time: 00:00:10)
Last failover time:             17:57:30 PST Feb 5 2014 from (139.241.97.22)
Last switchback time:           17:58:00 PST Feb 5 2014 from (139.241.97.21)
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 0
          Download Failed              : 0
          TFTP Download Failed         : 20
        Configuration Attempted        : 0
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command:
FAX mode: disable
Configuration Error History:
test2811#
Loading test2811.cnf.xml from 139.241.97.22 (via FastEthernet0/1): !
[OK - 57998 bytes]
This package type is not the default package type.
... here is the show ccm-manager after the domain name was deleted in the 2811's IOS config, which was not matching the CUCM...
[OK]
*Feb  6 01:59:52.143: %CMAPP-6-CONFIG_DONE: Configuration by CCM is done
test2811#copy run start
Destination filename [startup-config]?
[OK]
Second Backup   None
Last keepalive sent:            18:04:06 PST Feb 5 2014 (elapsed time: 00:00:11)
Last MGCP traffic time:         18:04:06 PST Feb 5 2014 (elapsed time: 00:00:11)
Current version-id: 1391645659-b582897c-6888-4f3b-8473-44d1776dc967
Last config-downloaded:00:00:00
Current state: Waiting for commands
          Download Successful          : 1   <---- cool, thank you
          Download Failed              : 0
        Configuration Attempted        : 1
          Configuration Successful     : 1
Last config download command: New Registration
FAX mode: disable
test2811#
I didn't realize that the hostname was bound to the domain name on the 2811's config.  The CUCM only had the hostname in the gateway's config.  As soon as the no ip domain name command was executed, the 2811 registered.  I'll probably be adding the binding commands just to make sure once its in production.  Thank you all for your help - very much appreciated!!!
George
- Job 38:36, - Psalm 116:5
thank you for the show ccm-manager input - very useful!
thank you again Kevin, this is what the production config will be using
VIP Purple
Hi George,
you can also run show ccm-manager hosts command.
regds,
aman
194
