Adding 9 to incoming calls (Call Manager Express)
How can I add 9 to incoming calls (calling party) with the translation pattern?
Bronze
Re: Adding 9 to incoming calls (Call Manager Express)
Hi, Used this on CCME in the past
Two Options but both do the job
The second option is dependant on the country dial pattern.
This is based on the uk where local calls had 6 digits (some areas have 7) and then 10, 11 and 12 digits for national and international etc
Option 1 is more straightforward
voice translation-rule 90
rule 1 /^0./ /90/
rule 2 /^1/ /901/
rule 3 /^2/ /902/
rule 4 /^3/ /903/
rule 5 /^4/ /904/
rule 6 /^5/ /905/
rule 7 /^6/ /906/
rule 8 /^7/ /907/
rule 9 /^8/ /908/
rule 10 /^9/ /909/
rule 11 /^00/ /900/
voice translation-profile Prefix_9
translate calling 90
voice-port 0/0/0:15
translation-profile incoming Prefix_9
Option 2 is a little more complex
voice translation-rule 2
rule 1 /\(^......$\)/ /9\1/
rule 2 /\(^..........$\)/ /9\1/
rule 3 /\(^...........$\)/ /9\1/
rule 4 /\(^............$\)/ /9\1/
voice translation-profile 1
translate calling 2
voice-port 0/0/0:15
translation-profile incoming 1
You could also apply to the incoming dial-peers
Hope this helps
Paul
ok thats fine, another question if we use CM and MGCP how can we do this? With the help of translation patterns or something else?
Bronze
You can do it on CallManager in the service Parameters, under the Clusterwide Paramters option either on the gateway or on the phone
This is where I normally do it with MGCP
Paul
You set it on Service parametre for CallMnaager service under MGCP section (MGCP Prefix) .
you need to know when you debug the incoming call is an :
1. Subscdriber,
2. Unknow,
3. International
Or you can append 9 suing translation pattern but make sure that only the E1/T1 endpoint hit this translatation pattern by using Partition and CSS
Husien
397
