Adding 9971 and 8961 - Not showing up in CUCM
Think I may have posted this in the wrong place before.
System version: 7.1.3.30000-1
Trying to add the 8961 and 9971 phones. Have uploaded the default phone loads, but they are not showing up.
Am I missing something?
Hall of Fame Super Red
Re: Adding 9971 and 8961 - Not showing up in CUCM
Hi Adam,
When the device you are trying to add (like the 8900 & 9900 series)
and it is not shown on the Add/Phone or Device default pages, you need to add
a new Device Pack to CUCM. Like the one in the path shown below
Cheers!
Rob
Thanks Rob! I'm just getting into the Voice side of things at our company and haven't loaded a device pack before. Can you give me some basic instructions on how to do so? I've downloaded the pack you provided.
Thanks!
Hi Adam,
No worries my friend
Please take a moment to read the attached ReadMe as this procedure will upgrade the
Firmware on all Devices;
Installation Instructions
6.             Note: Cisco recommends that you apply this Device Package during a maintenance window.
Procedure
NOTE: Apply this patch to all of your Cisco Unified CallManager servers, beginning with the publisher server and TFTP server.
When applying this Device Package to enable new device support, a cluster-wide reboot is required for those devices to register successfully.   A clusterwide reboot IS NOT required when running to update existing firmware/support.
For Cisco Unified CallManager 7.0, you must do all software installations and upgrades by using the Software Upgrades menu options. The system can upload and process only software that Cisco Systems approved. You cannot install or use third-party or Windows-based software applications that you may have been using with a previous version of Cisco Unified CallManager with Cisco Unified CallManager 7.0.
  1. Using      your web browser, login to the Cisco Unified Communications Operating      System Administration web page
  2. Under      the Software Upgrades menu, select Install/Upgrade.
  3. Fill      in the appropriate values in the Software Location section for the      file you downloaded above, and click Next.
  4. In      the Available Software drop-down box, select the file you      downloaded above, and click Next.
  5. After      validating the MD5 has the correct value, click Next.
  6. In      the Warning box, verify you have selected the correct firmware, then click Install.
  7. Check      that you received a Success message.
7.             Note: In order to change the loads manually, you do NOT need to reinstall this Device Package. The new files will be present in the TFTP folder. Go to CCMAdmin->Device->Device Settings->Device Defaults and manually change the name of the load file (for specific device(s)) to the new load and click UPDATE.
Note: If you are rebooting the cluster, the next step does not need to be done.
8.             The Cisco TFTP service now must be stopped and restarted on the TFTP server, then reset the affected devices for them to upgrade to the new load.
http://www.cisco.com/web/software/282074299/35230/cmterm-devicepack-7_1_3_33033-1_readme.html#_Toc248767202
Cheers!
Rob
Okay, getting there slowly, but surely.
Have the device pack installed now. I am able to see the devices in 'Device Defaults' and they have the correct load files.
I plugged the 9971 in and am not seeing several 'file not found', 'tftp error', 'no trust list installed' in the Status Messages.
Is there a 'next step'? h
Any help?
1093
