05-31-2010 07:12 AM - edited 03-15-2019 11:00 PM
I am trying to add a 2911 Voice Gateway to a Call Manager 5.1.2 as a MGCP Gateway. The 2911 is not an option to add. What version of 5 do I need to go to have the 2900 series routers available?
Cheers,
Derek
Solved! Go to Solution.
05-31-2010 07:19 AM
There is no 5.X version that supports ISR G2s as MGCP, the minimum you need is 6.1(5).
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-31-2010 07:19 AM
java
