Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Adding a subscriber communications manager server in a cluster
at this moment, we have only one publisher/subscriber in our IP telephony solution. Next month, we want to give it some redundancy adding a new subscriber and creating  a cluster with these two servers. I haven´t found any guideline about  adding a new subscriber, does anyone know if there is a guideline about it?
Thanks in advance
1 ACCEPTED SOLUTION
Re: Adding a subscriber communications manager server in a clust
Hello Daniel,
Sure. Here you can find the guide lines (I'm assuming you have a cluster version 7.X):
Install Software from a DVD on a Subsequent Node
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485604
Apply a Patch During Installation of a Subsequent Node
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485792
Add a New Node to an Existing Cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485892
Hope it helps, please rate if it does.
Good luck!
Kind regards,
- Adrian.
Hello Daniel,
Good luck!
Kind regards,
- Adrian.
Thanks for all.
467
