Adding Call Center to Hunt List
I have a CallManger 6.x and want to send calls to a group of desktops. If they don't answer, I want to forward the calls to a call center. I configured the desktops to be members of a line group. I have a CTI route point to send calls to the call center. The problem is that I can't add the CTI route point to a Line group and I can't add a translation pattern to a line group. My questions are:
1) How do I get the call to the call center if the desktops in the line group don't answer.
2) What happens to a call when the line group "Stops Hunting". Can I specify an action?
1 ACCEPTED SOLUTION
Re: Adding Call Center to Hunt List
Config Forward no Answer or Forward busy to the CTI RP under the hunt pilot config.
No, you cannnot define what happens if you choose Stop Hunting, it will simply stop upon the condition you choose.
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
135
