VIP Super Bronze
Adding/Delete Users on Secondary Unity server while its active
I just want to know if will be any issues with adding/deleting users on the secondary unity server while it is active and the primary is inactive.
I have got a customer whose primary server is inactive at the moment and wont be able to failback to the it until weekend but wants to know if they can administer unity with the secondary been active.
Are there going to be any issues with this...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
Re: Adding/Delete Users on Secondary Unity server while its acti
Unity will not allow you to do it. As soon as you login to the admin page on the standby server it will give you a link to the active server to make any config changes.
Chris
Hey Deji
as far as i can remember you should be able to do so, that's the whole point of having a failover server. Someone broke the failover i had at the lab so i cannot test is right now =( but you should be able to do so, SQL replication should take care of the changes and since both servers are looking at the same DC,GC, Exchange, etc all data can be accessed by both.
if you are running on the primary and you get into SAweb on the failover you will get the message that you need to do changes on the active server, but if you're running on the failover and haven't done fallback yet then you won't get that message and will be able to do the changes needed.
java
if this helps, please rate
java
www.cisco.com/go/pdi
VIP Super Bronze
Jamie,
Thanks for your response
VIP Super Bronze
Chris,
Thanks for your response. I guess you missed what I said. The secondary server is actually the active one now.
Tac confirmed that its okay to make changes when the secodary server is active.
111
