Adding external number to Corporate directory
Hi Guys,
Is it possible to add External PSTN numbers in Corporate Directory?
Say,
ABC Department - PSTN number xxx
XYZ Department - PSTN number yyy
When user searches and selects ABC department, it should go to xxx.
Can you please help me how to configure this?
Mady
1 REPLY
Re: Adding external number to Corporate directory
Hi, the quick fix would be to include these entries under global directory, if this is AD integrated you cannot add these as contacts, only as a user, that way the user will show up on the corporate directory.
Now that if you know a little about html, xml, asp and LDAP queries you can create your own corporate directory, you just need to modify the xmldirectoryinput.asp file to point to a custom directory.
144
