Adding >1 billing system for CDR's
Hey everyone,
Right now I am working on building a solution for our company that will give us some insight into A) customer experience and B) element performance. To do this, I am trying to get access to the CDR files that our Cisco BTS 10200 uploads periodically. Now I know these CDR's get uploaded via FTP to our billing system. However is it possible to add a secondary destination along with the primary destination, so each 1 record gets sent to both locations? This way we don't have to come up with some way to copy them from the billing system (a different organizational entity) before the files get absorbed into their database and purged.
Any pointers would be greatly appreciated, thank you!
1 REPLY
Re: Adding >1 billing system for CDR's
You don't mention your version so I'll post info for 8.X, if not your version, confirm it's the same by searching the same doc and section for the version you need.
Configuring Application Billing Servers
Use the following procedure to configure application billing servers to  which you want to send CDRs. You can configure up to three billing  servers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_0_2/admin/sacdrm.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
239
