10-04-2007 03:48 AM - edited 03-15-2019 06:48 AM
At CCM 4.2 - is it possible to adding h.323 gateway into Route group/list? When I try it, at "Insert Route Group" page I dont see any of my installed (and working) gateways. Why?
10-04-2007 12:36 PM
you can only add h323 gateways to Route Group's Only not Route Lists. So the order I usually set things up is: Setup H323 Gateway, Setup Route Group containing Gateway, then setup Route List with containing the Route Group.
Now I have seen instances where the H323 Gateway will not show up as an available device for the Route Group if it is already used in a Route Pattern that sends calls directly to the Gateway instead of a route list.
In that case you have to temporarily send those calls in the Route Pattern to some arbitrary device then finish the setup of your gateway/route group/route list and then re-confgiure your route patterns to go to the route list rather than directly to the h323 gateway.
10-04-2007 09:59 PM
You are right....the gtwy are already used at Route patterns, and thats a reason....
Thanks a lot for your advice,
br
10-04-2007 09:02 PM
This is a great document:
<http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_1/ccmsys/a03rp.html>
And this one too:
Take a quick read and if you still need any help please let us know. We will be more than happy to assist.
Ajaz
