Adding ICT trunk and SIP trunk into Route group
Hi ,
We need to map ICT and SIP trunk into the same route group  ,but the problem here is already same ICT is mapped to another route pattern.
If i try to create new ICT with same remote IP ,it's throwing Add failed because the remote IP is already defined.
Is there anyway we can add ICT with same remote IP and map the ICT and SIP trunk ? or Is there anyway that we can add exisitng ICT into route pattern.
Route pattern is used for this route group is different.CUCM version - 7.X.Please advice.
Ramanathan
1 ACCEPTED SOLUTION
VIP Gold
You can cot create a trunk
You can cot create a trunk with same remote destination IP and port. Anyway, first you need to un-map the ICT from existing route pattern and after that you can assign it to route group.
Suresh
VIP Gold
Suresh
Thanks Suresh ...In that case
Thanks Suresh ...
In that case ,I can assign the route group(ICT ,SIP - Top Down)  to two different Route pattern.
Both patterns will hit ICT first ,Please correct me if I am wrong.
Ram
VIP Gold
Hi Ram,Yes it correct, You
Hi Ram,
Yes it correct, You can assign this route group to a newly created route list and that route list can be assigned to any number of route patterns.
Suresh
133
