Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
adding incoming numbers
Hi All,
We have a Cisco 2801 Router with a 15 Channel ISDN and an internal IP Telephone System. Our Phone Service Provider has already given us a 100 range of numbers attached to the 15 Channels, but is going to add 2 additional individual numbers completely outside of this range.
I need to know that our router will accept calls for these numbers and pass them to our IP telephone server to determine which extension is to receive the call.
Currently I see two areas that refer to our 100 range as it is now. Would I need to add these 2 individual numbers in these areas as well?
translation-rule 22
Rule 1 02811780 811780
and the following I believe is only for outgoing calls which does not matter, I do not need calls to me made outgoing via these 2 additional numbers.
dial-peer voice 3 voip
translation-profile outgoing calling
destination-pattern 811780..
voice-class codec 1
max-redirects 10
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
If I have not made any sense, please ask me any questions you may have.
Thankyou in advance for your help.
Silver
Re: adding incoming numbers
Called number (DNIS) with incoming called-number
First, the router or gateway attempts to match the called number of the call set-up request with the configured incoming called-number of each dial-peer. Since call setups always include DNIS information, it is recommended to use the incoming called-number command for inbound dial peer matching. This attribute has matching priority over answer-address and destination-pattern.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Yeah we already had that set up. I just did not include it in my post.
dial-peer voice 1 pots
voice cut-through alert
description Incoming ISDN Dialpeer
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 2 pots
description Outbound DialPeer
destination-pattern 0T
port 0/1/0:15
destination-pattern 866780..
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
dial-peer voice 4 voip
destination-pattern A800AT
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
dial-peer voice 5 voip
destination-pattern .
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
I'm still not sure what to do here though. I think I might have a translation issue.
98
