Adding Licenses in CUCM 7.1.5
I am trying to add licenses to CUCM 7.1(5) through UCL. In recent discussion blogs, I see that I can use part codes for up to CUCM 8.6 and it will give me the required licenses (Because till CUCM 8.6, it's still DLUs in the backend.
I am using part code L-CUCM-USR-LIC-ADD and it is giving me CM-RTU as part code and not throwing any PAK.
Is it the correct method?
Thanks and regards,
Jaid Bagwan
Everyone's tags (1)
1 REPLY
VIP Purple
Hi , The PAK Codes you would
Hi ,
The PAK Codes you would get once place the order  .Opt for E-delivery to get the PAK codes and thereafter , u can generate license.
regds,
aman
192
