05-19-2009 04:26 AM - edited 03-15-2019 06:04 PM
We are using 2 CCM's with version 4.1(3)sr3b connected to 2 QSIG Gateways using 2 PRI lines.
I have had a request to configure the Callmanager in such a way that persons being called from three specific external numbers (79551, 79554 and 79552) can also see the name associated with those numbers. Those names are not being sent by the telco; is it possible to add names to those incoming numbers using the Callmanager?
If yes, how would I go around implementing this?
Regards, Marvin Woods
05-19-2009 08:12 AM
Are you using mgcp or h323 ?
05-19-2009 11:25 PM
Good morning,
used product: Cisco 2811
used protocol: MGCP
If you need more info, let me know.
05-20-2009 05:43 AM
I don't think you can do anything with mgcp.
With H.323, you can use some script like a I wrote to add a anme.
