07-17-2007 08:16 AM - edited 03-14-2019 10:37 PM
I have added new subscriber to the cluster. Everything went fine on the install. I can see this server from CCMADMIN and start services ect.
When I go to SQL server group I do not see the server there. Do I have to manually add this to the Group?
Solved! Go to Solution.
07-17-2007 08:38 AM
Yes, you can right-click SQL Server Group and choose New SQL Server Registration.
Hope this helps. If so, please rate the post.
Brandon
07-17-2007 08:38 AM
Brandon
07-18-2007 10:56 AM
is there any chance of the new subscriber over writing the database on the pub and wiping it out?
i'm sure the answer is "no" but i'm about to add a sub also and want to be sure.
thanks in advance.
07-18-2007 11:04 AM
I always hesitate to say that there is no chance of a particular event happening, but to my knowledge this could not happen by chance. It would require some specific steps with the intent to make this happen such as breaking the SQL replication, etc. By default, the behavior in a publisher/subscriber relationship is for database changes to be written to the publisher and then replicated to the subscriber. Changes are never replicated from the subscriber to the publisher.
Hope this helps.
Brandon
07-18-2007 11:05 AM
Hi Jerry,
You are correct! There is no chance of this happening. I have worked with many people who have added Subscriber Servers and have never had this happen.
Hope this helps!
Rob
EDIT: Brandon is correct :) This should be a 99.99999% qualified No!
07-18-2007 11:10 AM
thanks every one.
