Adding new users to Standard CCM End Users Group, System version: 7.1.2.20000-2
Is it possible in Version 7 to add new users to the Standard CCM End Users Group by default when they are syncronized from the AD?
1 ACCEPTED SOLUTION
Re: Adding new users to Standard CCM End Users Group, System ver
No, it's not possible in any CUCM version
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
262
