Adding Unity to existing Domain
During the initial installation of my Unity 4.2 server it was not added to the domain. The Sql is running locally on the server. What is the procedure to now add the server to an existing Domain.
Re: Adding Unity to existing Domain
unfortunately the only way to change a server from a domain is to reinstall the server.
Renaming a Cisco Unity Server or Moving a Cisco Unity Server to Another Domain
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_080.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
It is not currently on a domain, would the same apply
yes, that counts as changing the domain from none to something
java
java
Hall of Fame Super Silver
How did you install Unity wihout not being in domain? It's not possible.
Chris
You're right, it has to be added to another domain
126
