Adding voice bundle unified communication licenses for 2921 GW to be similar to CISCO2921-V/K9
hi,
currently i have and existing GW cisco 2921 and it is requested to upgrade it to match the features in CISCO2921-V/K9.
PVDM3-32= and VIC2-4FXO= was ordered separately but what about the licenses needed? FL-CUBEE-5= X2 is enough or i have to order SL-29-UC-K9= too?
what is the lower cost solution?
Everyone's tags (3)
It all depends on what is in
It all depends on what is in the existing router and what you are trying to do.  If you are adding FXO, FXS, and/or T1/E1 cards but you are not using CUBE functionality or SRST functionality, you need is the UC feature license, DSPs, the cards, and possibly a DRAM and flash upgrade.
For your reference, I have provided an example "stock" build of a 2921/K9 and 2921-V/K9.  By stock, I mean no options were added other than smartnet and a power cable.  The 2921 comes with some CUBE licensing, IOS UC licensing, a PVDM3-32, and more memory.  If you are buying a new gateway, it is usually cheaper to buy this package rather than buying the 2921/K9 and adding the features.
1.0CISCO2921/K9Cisco 2921 w/3 GE 4 EHWIC 3 DSP 1 SM 256MB CF 512MB DRAM IPBN/A14 daysNo1
1.0.1CON-SNT-2921SMARTNET 8X5XNBD Cisco 292112 month(s)N/ANo1
1.1SL-29-IPB-K9IP Base License  for Cisco 2901-2951N/A14 daysYes1
1.2HWIC-BLANKBlank faceplate for HWIC slot on Cisco ISRN/A21 daysYes4
1.3ISR-CCP-EXPCisco Config Pro Express on Router FlashN/A21 daysYes1
1.4MEM-2900-512MB-DEF512MB DRAM for Cisco 2901-2921 ISR (Default)N/A14 daysYes1
1.5MEM-CF-256MB256MB Compact Flash for Cisco 1900 2900 3900 ISRN/A21 daysYes1
1.6SM-D-BLANKBlank faceplate for DW slot on Cisco 2951 and 3925N/A21 daysYes1
1.7SM-S-BLANKRemovable faceplate for SM slot on Cisco 290039004400 ISRN/A21 daysYes1
1.8S29UK9-15401TCisco 2901-2921 IOS UNIVERSALN/A14 daysNo1
1.9PWR-2921-51-ACCisco 2921/2951 AC Power SupplyN/A14 daysYes1
1.10CAB-ACAC Power Cord (North America) C13 NEMA 5-15P 2.1mN/A14 daysNo1
1.11PI-MSE-PRMO-INSRTInsert Packout - PI-MSEN/A14 daysYes1
2.0CISCO2921-V/K9Cisco 2921 Voice Bundle  PVDM3-32  UC License PAK  FL-CUBE10N/A14 daysNo1
2.0.1CON-SNT-2921VSMARTNET 8X5XNBD Cisco 2921 Voice Bundle12 month(s)N/ANo1
2.1S29UK9-15204MCisco 2901-2921 IOS UNIVERSALN/A14 daysYes1
2.2PWR-2921-51-ACCisco 2921/2951 AC Power SupplyN/A14 daysYes1
2.3CAB-ACAC Power Cord (North America) C13 NEMA 5-15P 2.1mN/A14 daysNo1
2.4FL-CUBEE-5Unified Border Element Enterprise License - 5 sessionsN/A21 daysYes2
2.5PI-MSE-PRMO-INSRTInsert Packout - PI-MSEN/A14 daysYes1
2.6SL-29-IPB-K9IP Base License  for Cisco 2901-2951N/A14 daysYes1
2.7SL-29-UC-K9Unified Communication  License  for Cisco 2901-2951N/A14 daysYes1
2.8HWIC-BLANKBlank faceplate for HWIC slot on Cisco ISRN/A21 daysYes4
2.9ISR-CCP-EXPCisco Config Pro Express on Router FlashN/A21 daysYes1
2.10MEM-2900-512MB-DEF512MB DRAM for Cisco 2901-2921 ISR (Default)N/A14 daysYes1
2.11MEM-CF-256MB256MB Compact Flash for Cisco 1900 2900 3900 ISRN/A21 daysYes1
2.12PVDM3-3232-channel high-density voice and video DSP moduleN/A21 daysYes1
2.13SM-D-BLANKBlank faceplate for DW slot on Cisco 2951 and 3925N/A21 daysYes1
2.14SM-S-BLANKRemovable faceplate for SM slot on Cisco 290039004400 ISRN/A21 daysYes1
VIP Purple
Hi, In addition to good tips
In addition to good tips by Adcompto[+5] , u also need to activate the UC licenses on ISR G2.
you can refer the link
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
regds,
aman
3046
