Adding Voice to a standard 2921 ISR..?
Hello folks,
What extra parts are required to run Voice on a standard 2921 ISR? I am thinking just the following:
PVDM2-64
VWIC2-2MFT-T1/E1
Anything else?
IOS 12.X-ipvoice  "T" release
Thanks!
Is there any other hardware requirements that I will need?
Green
Shane,
A 2921 is an ISR-G2
You must use an IOS from the IOS 15 as they are not supported on 12
If you are pricing new kit
look at using PVDM3 ( More density)
  & VWIC3 type ad ons
They may even be cheaper
Alex
Regards, Alex. Please rate useful posts.
388
