Addition of CUCM to ELM fails due to security error
Addition of CUCM to ELM fails due to security error. What could be the probable cause for this ?
I went through the logs generated by ELM, but I didn't find any useful information.
Gopal.
1 ACCEPTED SOLUTION
VIP Purple
Hi Gopal, Check the
Hi Gopal,
Check the discussion if it helps.
https://supportforums.cisco.com/discussion/12104251/security-error
regds,
aman
Are you using the OS admin
Are you using the OS admin username/password?
Please rate useful posts.
yes, I am using OS admin
yes, I am using OS admin/password. Test connection was successful, but error message after hitting "Ok"
Error message is :
Product instance registration failed. A security error occured. Check the enterprise licence manager log for details. Would you like to add the product instance any way ?
VIP Purple
Hi Gopal, Check the
Hi Gopal,
regds,
aman
Hi Aman, Thanks for the link
Hi Aman,
Thanks for the link . It has useful information.
Removed the product instance, issued the below command on CUCM and it worked fine.
admin:license client reset registration
Gopal.
1088
