Community Member
additional IP Peer
can anyone give me a copy/sample of the config for ASA 5505 for additional IP peer.I got an existing connection (site-site-both's my current config...
I need it for the home user using netgear...he got dynamic ip.
interface Vlan1
nameif inside
security-level 100
ip address x.x.x.x
interface Vlan11
nameif outside
security-level 0
ip address x.x.x.x
interface Ethernet0/0
switchport access vlan 11
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxx encrypted
ftp mode passive
dns server-group DefaultDNS
access-list 101 extended permit ip any x.x.x.x
access-list 102 extended permit ip any x.x.x.x
access-list 111 extended permit ip host x.x.x.x host y.y.y.y
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list 101
access-group 111 in interface outside
route inside any x.x.x.x. 1
route outside y.y.y.y 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 20 match address 102
crypto map outside_map 20 set peer x.x.x.x
crypto map outside_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
pre-shared-key *
ssh timeout 5
console timeout 0
management-access inside
Community Member
Re: additional IP Peer
Groups and users are core concepts in the management of the security of VPNs and in the configuration of the security appliance. They specify attributes that determine users access to and use of the VPN. A group is a collection of users treated as a single entity. Users get their attributes from group policies. Tunnel groups identify the group policy for a specific connections. If you do not assign a particular group policy to a users, the default group policy for the connection applies.
