Addon Licenses for CCX 10.5
hi,
i am using CCW but i am not seeing any type of ADD-ON licenses for UCCX 10.5. Did some research and couldn't come across any either.
i need to add on 10 additional licenses to and existing deployment, but i cant seem to find add-on licenses.
all i am seeing are 5-seat bundles and 25 set bundles and i am unable to up the quantity of the 5-seat bundles to two.
i hope there is a way for add-ons
thanks,
Surendra
1 ACCEPTED SOLUTION
What top level part are you
What top level part are you using?  It should be single seats under CCX-10-ADD-K9...
Thanks!!! i was using R-CBE6K
Thanks!!! i was using R-CBE6K-K9 as the Top Level PN
I noticed there aren't any E
I noticed there aren't any E licenses though.. do you know if there is for CCX-10-A-P-LIC
895
