Adhoc conferencing giving busy tone when using non-default region
rramlal
Hi All,
This strange issue is occuring on call manager 9.1. When the default device pool is used on the phones they are able to adhoc conference each other. When a different device pool is used and a new region is created but has the same settings as the default region it is still giving the busy tone.
Is there a reason why this is happening?
brmeade
Level 4
Level 4
Default inter-region Codec unless you changed it is G.729.  Software conference bridge in CallManager doesn't support G.729 so a transcoder or hardware conference bridge must be used.  Your other option would be to just change the max audio bit rate between the Default region and the new region to 64kbps.
