Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Advanced Device Mobility
Can anyone tell me what this means: "DbMobility: can't find remdest  59854154"
This is a SDI trace entry, and I don´t know what thes mean.
thx a lot
Patricio
Re: Advanced Device Mobility
This is saying that the Remote Destination 59854154 cannot be found or cannot be dialed given the current digit strings.  Is this a valid dial string for your cluster?
Hailey
Please rate helpful posts!
Hi Did you find out what this means by any chance?  I'm having the same issue on a trunk between two callmanagers.
Thank you
Andrew
464
