Community Member
AF31 Header Packet in / Packet stripped going out
I am having outgoing packets to a SRST gateway not labeled with AF31 header bytes. I am recieveing the packets with the header just fine. This is causing qos issues and call control dropping during high utilization.
1 ACCEPTED SOLUTION
Re: AF31 Header Packet in / Packet stripped going out
The reason for the packets being re-written will be primarily because either the trust has not been configured on the appropriate ingress ports. Or if you are classifying based on ACLS, then possibly your ACLs are not matching correctly? Run 'show policy-map interface x/y' and see if packets are being matched for your signalling class?
From the packet capture it is traffic with the source address 172.22.32.16 which does not have the correct marking?
Therefore you will need to verify your QoS settings for the network path between where this endpoint is connected and where the packet capture was taken. Between these points the control traffic was obviously remarked.
If this host is your CallManager? then ensure the switchport is configured to trust DSCP as mentioned in a previous post and nothing else.
Allan.
Community Member
Here are 2 screenshots of Wireshark captures
Hall of Fame Super Silver
Are your trust bundries set up properly? Are you trusting DSCP values on the GW link, as well as the WAN router link? Do you use policy-map on the router egress?
What's the WAN connection, if MPLS ensure the provider does not override these packets.
HTH,
Chris
Community Member
These are our captures out our Router before they go over our MPLS WAN link to the SRST location.
Are these taken at the main site?
Are you trusting DSCP values on the CM uplink, with the follwoing command:
"mlq qos trust dscp"
Chris
Community Member
the SRST router?
Community Member
And yes, all policys are in place on Both ends... It seem this is not being placed by the Call manager.
Allan.
144
