after-hours and CFwdAL problem
Hi all guys,
Frist of all thanks for ypur help.
I implement After-hours to restrict call to PSNT with pin and login, all workin fine, but when a user try to use the call forward all to PSTN cannot do it, after he is login.
Do you know how to use Call forwarding all with After hours blocking.
Regards.
Hall of Fame Super Red
Re: after-hours and CFwdAL problem
Hi Robert,
I don't think you have missed anything in fact this is working as expected. The Call Blocking applies to CFA as well as other call types. The only thing that I can think of is to make calls to your pre-defined Call Forward external numbers exempt;
Call Blocking exemption;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a0080877938.html#wp1016962
Hope this helps!
Rob
The other thing you could do is put your pin into the number string that you are forwarding to.
Hi jgentsch
Thanks for your help, im crazy right now, with this issue, I setup After-hours blocking sucesuful, but the problem its cannot use call Fordward All.
I hear a Promt frommy Carrier say: call cannot be completed, so i get some debug.
I Use also this patterns in the debug screens:
after-hours block pattern 7 1.......
after-hours block pattern 8 1044T
110
