After-hours PIN fail
Hi all!
I don't know if it's a bug or a config mistake but I can't config after-hour with pin login in CME 7.1
I have this config,
telephony-service
 after-hours block pattern 1 0537719.T
 after-hours block pattern 2 941
 after-hours day Sun 00:00 23:59
 after-hours day Mon 00:00 23:59
 after-hours day Tue 00:00 23:59
 after-hours day Wed 00:00 23:59
 after-hours day Thu 00:00 23:59
 after-hours day Fri 00:00 23:59
 after-hours day Sat 00:00 23:59
ephone 56
 ephone-template 15
 pin 1234
I login successfully,
sh ephone login
ephone 56       Pin enabled:TRUE        Logged-in:TRUE
But, when I try to call fails...
I observed that CME is blocking by after-hours config but I think that is not correct!!
debug voice application callsetup
 //42//Dest:/IsDestBlocked: Called number 941519397 is blocked by After-Hours Blocking.
Some ideas?
Thanks in advance!
Hall of Fame Super Red
Hi David, I think that
Hi David,
I think that pattern would be blocked due to your config;
To define a pattern of outgoing digits for Call Blocking from IP phones, use the after-hours block pattern command in telephony-service or ephone-template configuration mode. To delete a call-blocking pattern, use the no form of this command.
after-hours block pattern pattern-tag
no after-hours block pattern pattern-tag
Syntax Description
pattern-tag
Identifier for a call-blocking pattern. Up to 100 call-blocking patterns can be defined in separate commands.
pattern
Outgoing call digits to be matched for blocking, including specific digit patterns and general regular expressions.
7-24
(Optional) If the 7-24 keyword is specified, the pattern is always blocked, 7 days a week, 24 hours a day. If the 7-24 keyword is not specified, the pattern is blocked during the days and dates that are defined with the after-hours day and after-hours datecommands.
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_a1ht.html#wp3719778986
Cheers!
Rob
Thank you Rob but the problem
Thank you Rob but the problem another.
I would like to exempt ephone from block when it is logged-in with pin.
Like in this link.
https://supportforums.cisco.com/document/74711/after-hours-call-blocking-cme
Regards.
101
