After power outage the software of Unity 4.X
Hello everybody.
I have a problem with a customer, after a power outage the software of Cisco Unity does not work, the server is up and running.
How I can manually start the software of Unity or do I have to reinstall all over?
Thank very much in advance
Walter Flores
1 REPLY
Re: After power outage the software of Unity 4.X
Check to see if the service AVCSMGR is started. If it is not start it. If it does not start look in the event viewer to try to see what the cause is. You should not have to reload Unity Thanks
Jason
105
