Community Member
AIM-CUE not working anymore.
I have a 2851 router with an AIM-CUE installed.  All was working well until the power supply quit working.  I replaced the powers supply and the router is back up and running.  I did pull all modules during the testing process and replaced them into the router.  Everything works except the VoiceMail.  When I dial the extension for VM, it is just dead quite.
I opened up a termserv program and was able to capture the following:
Initializing memory.  Please wait. ... 256 MB SDRAM detected
BIOS Version: Cisco SE-AIM 01.02
BIOS Build date: 08/14/03
System Now Booting ...
001330: Jun  3 2014 19:32:12.209: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down[BOOT-ASM]
Please enter '***' to change boot configuration:
001331: Jun  3 2014 19:32:32.209: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
root cmd : root (hd0,0)
 Filesystem type is reiserfs, partition type 0x83
kf: a1 : /bzImage root=/dev/hda1 ro plat=aim
kf: a2 : /bzImage root=/dev/hda1 ro plat=aim
in grub_open: /bzImage root=/dev/hda1 ro plat=aim
in grub_open1: /bzImage root=/dev/hda1 ro plat=aim
in grub_open2: /bzImage root=/dev/hda1 ro plat=aim
in grub_open3: /bzImage root=/dev/hda1 ro plat=aim 1
In get_kernel_sig
in grub_open: /sbin/cisco_init
in grub_open1: /sbin/cisco_init
in grub_open2: /sbin/cisco_init
in grub_open3: /sbin/cisco_init 1
in grub_open: /sbin/.app_sig
in grub_open1: /sbin/.app_sig
in grub_open2: /sbin/.app_sig
in grub_open3: /sbin/.app_sig 1
Chksum: final image size: 2614590
Dbg ********* filemax/data_len/SECSIZ: 1795528/3072/512
   [Linux-bzImage, setup=0xc00, size=0x1b57c8]
 kernel_func: kt: 3
in boot func: kt: 3
Debug: bl_sz: 96160
Debug: cisco_bl_sz: 59994
0x0000007f 0x00000045 0x0000004c 0x00000046 0x00000001 0x00000001 0x00000001 0x
00000000 0x00000000 0x00000000
cisco_cl_addr: 0x10019c0
Debug: bl_sz: 96160
loader_addr: 0x1200000
signatures do not match...
Corrupted bzImage detectedÿ
001332: Jun  3 2014 19:36:12.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
System Now Booting ...[BOOT-ASM]
001333: Jun  3 2014 19:36:32.232: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
In get_kernel_sig
 kernel_func: kt: 3
in boot func: kt: 3
Debug: bl_sz: 96160
Debug: bl_sz: 96160
001334: Jun  3 2014 19:40:12.254: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to down 256 MB SDRAM detected
001335: Jun  3 2014 19:40:32.254: %LINEPROTO-5-UPDOWN: Line protocol on Interface Service-Engine0/1, changed state to upFound disk 0
found 1 drives
In get_kernel_sig
Any suggestions how I can get my voicemail working again?
Everyone's tags (1)
Hi, Have you work thru the
Have you work thru the following document?
Reinstalling a Cisco Unity Express Image Using the Boot Helper
The boot helper method may be used for emergency situations when your system is not responding as
required or for a new installation. The helper supports only installations of licenses and full images. The
boot helper mode does not support upgrades or language-only installations.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel3_0/installation/guide/30instll/upg3boot.pdf
Voice CCIE #37771
Community Member
Thank you, I will give that a
Thank you, I will give that a try.
Question, Since I am doing a fresh installation, can I upgrade to a newer version of CUE?  I think I had 3.1 before.  No real idea as it came already installed on the AIM module.  My router is a 2851 with IOS 15.1.  Please note, I do not want to spend any money for this if possible.  This is my home lab and I cannot afford Cisco's prices.
* Licenses with - NR-are
* Licenses with - NR-are licenses that are installed in the factory or licenses that are issued as a replacement for legacy licenses. By default, the NME-CUE is installed with 8 Voice ports and the AIM2-CUE/AIM-CUE are installed with 6 voice ports. By default, the ISM-SRE-300-K9 is installed with 2 voice ports.
So it seems like the license will still work from 3.1 to the latest one.
Voice CCIE #37771
83
