AIM-CUE to NM-CUE
Is there a way to export Configuration, Application Data and Voice Mail Messages from a AIM-CUE actually working to a NM-CUE without the need to create mailboxes or users messages??
AIM-CUE v2.3.4 and wish to upgraded to v3.0.2 in NM-CUE.
1 ACCEPTED SOLUTION
Re: AIM-CUE to NM-CUE
Before upgrade to v3.0, you will need backup your vm and config to a ftp server, cue only support ftp backup (uc520 will support backup with CCA tool and is another story).
cue# config t
cue#(config)# backup server url ftp://x.x.x.x/backups username username password password
cue#(config)# backup revisions 10 (the maximum backups kept on server)
cue#(config)# exit
cue#
cue# show backup
Server URL: ftp://x.x.x.x/backups
User Account on Server: username
Number of Backups to Retain: 10
use the gui interface to backup your vm and config. Or use below cli command to backup:
1. offline
2. backup category all
3. continue: This command bring back to online mode from offline.
4. show backup history
5. show backup server
After upgrade to the new version 3.0, on the new system config the same FTP server as backup, command will be the same as above.
After setup the ftp on cue, restore the config and VM to the new system:
cue# show backup server
cue# offline
cue(offline)# restore id nn category config data
Note: if you use "restore id nn category all" will cause restore failure as historical restore is not allowed by system.
Hope this helps.
Wayne
P.S, the ftp server I'm using is FileZilla Server, which is a fast and convenient one to use.
Hall of Fame Super Gold
for config, you can do "service-module session" to connect to CUE, do "show run" and that is your config that you can paste back into new module. I think it's possible to save messages too, but I'm not quite sure how.
Thanks for your answer, but actually that's my problem I need to solve, the personal messages is what I most like to keep. Any idea how to do it??
Cause in the NM-CUE menu via GUI, the restore option is gray, I can't select it. The NM-CUE is new with v3.0.2
cue# config t
cue#(config)# exit
cue#
cue# show backup
1. offline
cue# offline
Hope this helps.
Wayne
Thanks for your comments that help me solve my problem.
The reason that I had a grey option in the restore Menu, was because the Backup/Restore configuration option, was not correct the directory.
Best Regards,
You are welcome my friend. Glad to know you work it out.
Cheers,
Wayne
As long as you have the same version of CUE running on both platforms you "can" back up the CUE. There are three types of backups; configuration, data or all.
The data backup option backs up scripts, recorded names, user messages and custom prompts.
If you log into the CUE you will need to set up a backup server which is just an FTP server. Once this is setup you can put the CUE into "offline" mode and issue the back up command.
Check out the following link for the full detailed commands:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/install/app_back.html
Incidentally, you can restore to a newer version of CUE (it's not like regular Unity, where the restore requires the same version where it was backed up from). You just can't restore a backup from a newer version of CUE to an older version of CUE. The hardware platform does not matter, as long as the licensing is the same or greater (i.e. you can't restore something to an AIM from an NM if the amount is greater than what the AIM supports)
You should be able to backup the older version (regardless of hardware platform) and restore it. You do need to make sure you have the same software license (or at least as many mailboxes and the same type).
The new restore should work. I'm guessing the restore option is grey because it doesn't have a backup server configured, username/password or something.
917
