AIM for transcoding
Can you use AIM for transcoding. There is no information for the AIM
Bronze
Re: AIM for transcoding
I don't see how you can use AIM for transcoding as transcoding require the use of DSPs and I am not aware of any AIM that feature this. You would be better off using NM-HDV modules for your transcoding requirement or PVDMs.
http://www.cisco.com/warp/public/cc/pd/unco/ps4952/prodlit/cftr_ds.pdf
The AIM-VOICE-30 provides digital signal processor (DSP) services, which can support up to 30 medium-complexity or 16 high-complexity voice channels. So I guess they do have DSPs. Also the data sheet mentions that it can understand a variety of codecs.
Thank you
Sanjith
Gold
AFAIK, with the old routers 26xx/36xx/37xx, Transcoding can only be done by using DSPs of an NM-HDV and with the new gen ISR routers, you can install PDVMs on-board the router or on NM-HDV2 and use it for transcoding.
AIM-Voice-30 does not support CFB or XCODE
102
