Alerting Name presented between CME and CUCM
Hi All,
I have a customer who is currently on a CME system, they then purchased a CUCM.
The CUCM is running in parallel to the CME, with a small number of users migrated from CME to CUCM.
The CME is configured as a h323 gateway in the CUCM.
There are dial-peers in CME to point to the CUCM for those users that have been migrated.
Calls between the systems are fine.
Is there a way of sending or receiving the alerting names of the users on the different systems? An extra command under the voip dial-peers perhaps?
When I call between 2 CMEs I see the alerting names between them.
Felix
Everyone's tags (6)
Silver
CUCM should be seeing the CME names by default.  For CME to get names from CUCM through H.323, make sure you have "
Getting customer to test this, will let you guys know.
Thanks for the prompt responses
Hall of Fame Super Silver
Is "Display IE Delivery" checked on the H323 GW in CUCM?
Chris
330
